Bad Serial ATA port!?
Silvers24
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
I bought this back in 2007, (12th month of that year) (from newegg)
And just tonight, my whole computer took a crash.
The POST was showing my two DVD roms and my second hard drive, but my main hard drive had disapeared.
It turns out, that the port of which my main HDD sat in does not read my HDD any more.
Did it just suddenly die on me!?
What should I do? What can I do?
I need the second HDD just as much as I need the first one.
Gig says I have 3 years warrenty, should I try their rma? Is it worth it?
Or would one of them raid thingies work?
I never had this problem. :(
Check your cables first. Could be loose. Swap them with your secondary drive's cables to be sure.
Already did all that.
Everything is in order and as feared. Bad Sata port.
Suggestions?
Call and rma before its too late. No magic fix that I know of. See if they will do an advance replacement. Antec let me one time, but I don't know about Gigabyte.
