my new build started acting weird recently, first it started out being extremely slow, one hard drive w/ OS works on a different computer but slow, the other data drive ( WD6400AAKS ) spins but doesn't show up. but that's not, it makes the good working hard drive not work. whenever i try to use it, the windows loading screen shows up and the bars keep moving forward and sometimes the computer restarts by itself. now one of my fans won't run. you think the PSU might have gone bad. if it is how do i check if the mobo is still ok. i got the 680 watt psu from an older system. my confiuration was
Q6600 @ 2.4
2 X 2 GB G.Skill PC1000 @ 800 MHz
Thermaltake 680W PSU
Foxconn 8800GTS 640 Factory OC
Two HD, 640AAKS and WD1600 Cavier SE 16
EVGA 750i FTW
SATA DVD drive
6 12V case fans
Thank You
Q6600 @ 2.4
EVGA 750i FTW
SATA DVD drive
6 12V case fans
Thank You
