I have an old system running windows home server. Specs are 3200+ a64 venice, 1GB ram, 2 SATA hdd's, nvidia 6200. I don't know what the problem is, I turn it on, everything seems fine for a few hours then when I try to connect it will say "server not available".
So when I go to check on it,the system is powered off, I turn it back on and it boots right back up, rinse, repeat. It is one of those crappy ultra 500watt PSU's, the only reason i'm using it is because my spare enermax 350 didn't have 2 SATA power cables.
At first I thought it might be a heat issue because it's kind of in between a file cabinet and piano, and there is a bug in WHS which makes the cpu run 70-80% most of the time. It does have room on either side of the case though, but none the less I added more fans still same thing. It counldn't be a heat issue anyway because wouldn't that just cause it to keep rebooting and not shutdown completely?
So does this sound like a PSU issue or something else?
