Well, my powersupply went bad last week, and it fried my motherboard (Abit IC7-G). I replaced the powersupply, and then machine wouldn't boot, just kinda beeped at me. I tried most of a day to get it working, but no luck. So I just decided to replace it with the ASrock 939 Dual-Sata2. I had planned a complete upgrade after I had saved up the money, but this was unexpected, and I miss having my computer. I should be fine with my 1 gig of Corsair ram (unless someone can recommend something better that isn't bad ;-) ), the power supply I just got to replace, as well as my optical drives and case. The question is my video card. I currently have a Sapphire X800XL AGP 256 mb card, that quite possibly bit the dust (just the way it was acting before I found out the powersupply was bad).
Now I've been reading the reviews and comments made by people about different video cards and manufacturers, but I'm looking for your opinions and recommendations. do I go with one of the previous generation cards (X800/850, 6800 etc) or do I look at one of the mid range/lower end high cards thats out now (X1600, 7600 etc). I wish I had more I could spend on this build, but this was unexpected. I will still do a complete new build, probably later now that this happened. I'm looking to spend between 100-200$ on the video card, cause I do want performance, unless someone can talk me into spending the extra money on a more expensive card that could be used in my build next year.
I'm open to suggestions.
Thanks!
Thanks!
