Bad Motherboard?
bigmerv
What kind of problems could a bad motherboard cause? Could it cause my whole system to go whacko? I tried to install windows on 2 separate hard drives (not new but not old) and am getting errors, could this be a motherboard problem?
I don't know if it's a faulty motherboard or not. I'm asking if a faulty motherboard could possibly cause those problems
The motherboard is the most important part of your computer (not from a usage standpoint but from a stability standpoint)
The symptoms of a bad motherboard could be ANYTHING because EVERYTHING connects to it.
==>Lazn
i had that same issue with my asus a7v133. prolly ur ide ports r gone.
That's a rare problem. Bad IDE ports don't usually "happen".
If you're having stability issues, make sure your processor isn't overheating. Next check your bios settings and then move onto memory. If all that stuff checks out good, and you've changed all your cables and checked your power supply voltages, then it's likely to be a motherboard.
Personally the CPU is the last thing I call bad. The motherboard is the second to last thing I call bad. I'd check out everything else first.
What errors are you getting? That's the first thing we need to know to help you solve this. Tell us more about your system specs. Hard drive sizes and brands, memory information, processor and ram info. Power supply information is handy if you've got it.
i had recent issues with my new Epox 5EPA+ Motherboard, and it wasent the motherboards fault... well kinda but not really... it just turns out it didnt like my Corsair 3200LLPT memory... so i sold that and got some mushkin and now it seems to be running stable again.
Some boards don't like certain memory modules. For instance the D865PERL doesn't seem to like Corsair Value Select memory at all. I tried it on two different boards before stumblinb across a thread on the Corsair Forums about it.
Most problems:
Dirty/scratched install CD, more common than you can imagine.
Bad/unstable memory.
Bad cable
1 time in the last 9 years I had a bad board cause install problems, MSI KT133a board. Every other install problem was caused by the 3 I listed above.
You have at least 2 IDE controllers on the board, swap over to the other controller and try again.
if you list the symptoms you are experiencing in detail then i will almost certainly be able to tell you what the problem is. but motherboard problems are very, very, very rare and usually manifest in the form of the computer refusing to POST at all.
Sorry for not elaborting earlier I am having limited computer access since mine is down.
Ok, the memory is mushkin level 2 performance pc2700 512mb which I ran Memtest86 on through 8 passes and 0 errors came up.
The hard drives are an 80gb seagate barracude which is about 3 years old, and the other is a <1 year old western digital 200gb.
The processor is a brand new athlonxp mobile 2600+ which is not posting at 2ghz, and ive adjusted some settings like jumpers and bios settings to fix this, but to no avail. However since I had problems I did reset the CMOS to its defaults. Also, the bios is reporting the CPU temp at 27-29 degress C.
Right now I only have 2 ide cables (1 is brand new that came with the motherboard) and the other is about 1 year old. Ive switched them around and it doesnt seem to make a difference.
The power supply I don't know that much about other than its rated at 300W. I havent had much time to check voltages either but from the little amount of time I've had it looks like they are ok, some are fluctuating a little but it appears to be ok.
And lastly the motherboard itself, I know it's not the greatest but I'm in college and on a limited budget. Machspeed venom V2DP
As for the errors I receive, I've received several ranging from: unable to format drive (after it went to 100% on the format), Bios recognizes a hard drive (error only occurs on 1 hard drive) but windows setup cannot detect it, Windows exception STOP: 0X0000007B, corrupted files during windows install or files not found on cd.
I appreciate all the help, and look forward to the replies.
