allenwr1505
- Oct 16, 2003
I was recently got a Compaq Presario 5000T for free from someone at work. They had thought that it was broken, but I had somewhow fixed it. Or supposedly "fixed it." I took it home and installed a 120GB Western Digital Hard Drive and then installed Windows XP. Its specs are as follows.
667mhz PIII
Micro ATX Compaq motherboard
256mb 133mhz SDR
integrated graphics card
120 GB 8mb cache WD drive
235watt Powerman power supply
At first when I installed Windows XP it worked fine. However, when I was installing from Windows Update, the computer rebooted before the updates were complete, and it hanged when it was entering Windows. I tried rebooting several times without success. I then ran the Windows XP cd again. I ran check disk, and it fixed a couple of errors. I then told it to "fixmbr" to fix the master boot record, which it said was corrupt. After that the computer worked, and I finished installing the updates and transferring my files. A little while later, when I was transferring my files, the computer rebooted again. This time I could still get into Windows, but this worried me. I examined the computer, and noticed that the fan on the power supply wasn't working. I got a new 235 watt power supply and thought that the source of my problems had been the power supply overheating.
However, to test out the computer, I tried running Prime 95 overnight. When I woke up the next morning, the computer had all of its power LEDs on. From the light, it appeared that the hard drive was working constantly, which was kind of strange. I tried turning on the monitor, but nothing came up. Frustrated, I tried pushing the power button on the front of the case, but it wouldn't even turn off. I tried even opening the CD-ROM, but it wouldn't respond either. Eventually I just flipped the switch on the power supply. I rebooted the machine, and it would get to the Windows logo "loading Windows" screen, and would then hang. The screen would go blank, as if I was restarting, and all of the power LEDs would light up. Nothing would respond. I tried opening the CD-ROM again, but even that wouldn't respond.
I used the Windows XP Cd to run chkdsk and fixmbr again, but they didn't fix the problem. I still had the same problems when going into windows.
When the guy gave me the PC, he told me that he thought that there wa a problem with the motherboard. Is this a problem with the motherboard? I know that all of the parts work, and I've tried two power supplies. He used to have this same problem. What kind of problem would make all of the LEDs light up, and nothing respond? What kind of problem would prevent the CD-ROM from even opening? I thought that the CD-ROM could open independent of the state of the motherboard, as long as it had power. So is it a problem with the power supply? Should I buy another motherboard? And where would I get one that would fit in that Compaq case?
667mhz PIII
256mb 133mhz SDR
