I recently ordered an i3-540 and ASRock H55M-LE off of NE. Right from the beginning, things just weren't working right. Initially the computer just wouldn't boot with both sticks of RAM installed. So I thought it was bad memory, but after using multiple sets, and testing each one, one at a time, it turns out that something is off with memory slot 1. But finally at some point, it booted with both, and seemed to boot up every single time after. So I left it alone.
Then I began overclocking... and noticed some strange behavior. Prime and OCCT were giving me stability all the way up to 4.4ghz, but there just these random hangups and reboots - even during idle. So I figured my overclock was unstable. I backed it down to stock, as I had to move a bunch of stuff of of the 250gb drive onto an external. When I plugged in the external (via USB) and began copying, about 10% of the way in, the system froze and rebooted. What the fucking hell! And now the external doesn't even show up under my hard disk drives when plugged in (even though it's detected and showing up in Disk Management, I cannot do anything with it).
I also remember at some point getting upset, and lightly hitting the case, which caused some kind of weird freeze where it looked like a VRAM failure (colored blocks everywhere) - except I'm using the IGP on the i3?
Cold booting overall is a hit or miss. Sometimes it'll cycle on and off 3 times before it boots. Sometimes it will boot on the first try. If it was a bug, it should be a consistent issue? The cold booting is not consistent at all.
I've requested an advance RMA from NE, but damn... I've wasted too much time here. I was having fun with this i3 too.
