I just got my case in yesterday and I've had the rest of my components for a few days now, still waiting on my hard drive. So tonight I slap it all in the case and I run into a problem. I got no video and no keyboard lights. I I proceded to unplug everything, reseat everything, double check my connections and run with the least possible. That didn't help.
So I went and took it all out of the case, thinking maybe I grounded the motherboard out somewhere or something. Still nothing. I tried swaping the ram around, nothing. Another that doesn't work is my power switch, it only turns it on, it can't turn it off no matter how long I hold it in.
The hardware I have is:
AMD 4400 Dual Core w/ stock heatsink
ASUS A8N SLI Premium
OCZ EL 1024x2
Enermax Noisetaker 600w SLI
BFG 7800 GTX OC x2
Benq burner
So thats what I got, I've swapped the video cards around many times. I swapped the ram around, used only one stick, etc.
Looks like my motherboard is DOA, what does everyone else think? I'm going to send it back on Thursday after I see some replies, maybe there is an answer to my problem. Maybe its something so simple and easy.
Oh yah, one more question. On the BFG cards, with dual DVI, which DVI port in the primary? The one beside the small black round port?
I'm going to try and locate a PCI card tomorrow at work and bring it home to see if I get any video off that sucker. Maybe I got two bad BFG cards, lol.
Thank you for any help.
Brent
OCZ EL 1024x2
BFG 7800 GTX OC x2
Benq burner
Brent
