Hey all. I'm in the process of building a new comp, and have already ordered everything but the graphics cards. After doing research on them, however, I think I might have made a bad choice for my motherboard. What I have is this:
Asus P5K Deluxe
Corsair Dominator DDR2 1066 - 4GB (2x2GB)
OCZ EvoStream 720W PSU
Intel E8400 CPU
I'm using a 24" wide screen Dell monitor @ 1920x1200. I was planning on getting an HD 4850 to upgrade the cooling on and OC a bit, then decide whether I want to go the extra bit and get a second to CrossFire. With the res. I run, though, it sounds like the 1GB RAM version might work better (or even get a single 1GB HD 4870). Also, if you look at the mobo specs, it says:
Expansion Slots
PCI Express x16 2 x PCI-E x16 (blue @ x16 mode, black @ x4 or x1 mode)
To clarify, does this indeed mean that the second card (in CrossFire) would only run at x4 max (presumably with the other at 12x?); will this prove to be a significant performance change from a x8/x8 setup, like the 2 below?
If that's the case, I might sell the mobo I bought and get another one, perhaps one of these (which has PCIE 2.0 [Does the 1.0 -> 2.0 jump really improve that much?] and CrossFireX for x8 slot):
ASUS P5Q Pro
MSI P45 Platinum
or anything else you recommend. Thanks in advance!
Asus P5K Deluxe
Intel E8400 CPU
Expansion Slots
ASUS P5Q Pro
MSI P45 Platinum
