Bad luck going Good
Zoramac
Talk about bad luck going good, I just RMA'd my new system. Mobo, PSU and HD's (psu killed the drives but sent the mobo back before i figured out it was the new antec psu). tested the system for 12+ hrs w/just pump when i set it up. ran for 1+ week before the hds died. sent it all out last week, look at the case today= all the water drained out of the reservoir, when i checked it the hose wasnt in the quick connect all the way(out about a 1/4-1/2 inch) must have beed caught on something because when i gave it a slight turn it popped in all the way. I can only imagine what would have happened if i didnt have the problems i did to pull everything out when i did. :eek:
Well im sorry to here about all your hardware borking. But you were lucky that it did b4 the water leaked all over it. And extra lucky that it didnt leak once you get your new parts.
Hope everything turns out ok.
