Bad image quality on dual display
EvilNick
Hey guys, I have a problem with my dual display setup and was hoping to find a solution here.
I've got a NEC 1760V connected to analog and a Dell 1704FPT connected to DVI on a 9600XT. The Dell looks fine, but the NEC image quality is terrible.
Previously before I got the Dell, the NEC was fine, but after switching to a dual display setup, it's started looking crappy. Colors are off and I can barely read text.
Any ideas? :)
Switch back to single display to see if NEC still does that. If not, most likely the monitor doesn't like dual display. You can also try a different video card to be sure.
When back to single display, it's fine, back to normal.
It might be the video card, I dunno. I have this 9600XT on loan from my shop's warranty department while waiting for my 6600GT to get back from RMA.
