like the topic states, i flashed my bios to a newer version. upon reboot all i get is a black screen. no post, no beeps, nada. is there a way to recover from a bad flash? it's the mobo in my sig. thanks for your help.
its possible for a recovery using the info provided at site, but may not work, in my case did not work my floppy didnt boot etc.. i ordered new bios chip and when i get today sending old 1 in to be flashed as well it was only an extra $10, on top of the $25 for new bios chip, so ill have 2 now in case happens ever again.
An easy way to try to reaccomplish your BIOS is to clear your CMOS. Take a look in your MB manual, it should tell you what jumpers to move in order to clear your CMOS and return your MB to its default settings...it takes like 5 minutes.
contact asus support. many of their boards have a function that lets you recover from a bad flash, using a floppy, that takes about 10 or 15 minutes. this is a fact, tho not very well known. give them a blast. if not, do the biosman.com thing. that guy rules.
i did all the options i could find, removed battery, shorted jumper pins, tried to boot off floppy per instructions on biosman site, but ultimatly had to order, and great experience with them, not just fast shipping, but great customer service.(mad at fedex guy, left envelope in my mailbox, least safest place where i live, didnt know they were even allowed to do that.)
Good to hear you got it fixed. Seems to be a lot of bad flashing lately.
No need to resinstall anything; but most manufactuers do recommend that on first boot after the flash, you enter the BIOS and reset your settings to the "Fail Safe" defaults before you proceed. Probably just a cautionary move, in case you have some whack setting that the new BIOS doesn't like. Then when things are okay, go back and monkey around...
