Bad Axe 2 hard drive connection question
Liver
Going to be using 2 to three SATA drives with the Bad Axe2.
One will be a Raptor for the system files and such, some games
Second will be music and games and other random stuff
Third will be strictly for back ups (and I will open case and disconnect SATA and power when not needed). Or I may put this in an external eSATA case, either way it is a backup only (I know if I do this option to use the red connection).
Which SATA connectors on the motherboard should I use for best performance? After reading the manual they seem all the same.
I will not be running a RAID at all. Put each drive on each controller? Or put all on same control and disable one controller in BIOS (if possible)?
That sounds like a plan, use the Intel controller IMO. The only thing is if you disable the other one the HD LED stays on all the time. Hopefully someday Intel will issue something to fix that.
thanks andy, but I hate to admit. Which ones are the Intel ones? I would rather use those (as suggested). The others are marvel, right?
The Intel ones are the ones that are all black higher up on the board. Yeah, the other ones are Marvell. You have the owners manual for this board, right? Oh yeah, one more thing I found out...if you set up the SATA controller in BIOS as AHCI (which is a good idea before loading the OS), you lose s.m.a.r.t. access for the drive temp, good stuff eh? I think the perceived benefits of having the controller running as AHCI may outweigh being able to see the drive temps though. Maybe Intel will fix this too, lol. I like my board anyway though.
good advice. will do that. good to read the black ones are intel. my sata cable is not long enough to reach the drives with the blue connectors.
just waiting on the power supply now, everything is already installed.
