Well I think this motherboard is bad. It takes an quite a while to post. It seems to hang for a couple minutes while detecting IDE devices. I've tried two harddrives in it and XP seems to be able to format them although this is also taking longer than usual. The problem is that after it installs setup files and does it's first reboot, the harddrive is not bootable for some reason giving me a disk boot failure.
I flashed the BIOS to the latest (1.06) but that didn't help. I think the IDE controller is toast. I am going to put both harddrives in another rig and do a format and install of XP just to verify that they are ok.
What do you guys think? Am I on the right track?
