Krayzie135
- Jul 27, 2005
i bought an external drive to backup all my pics and music onto and want to know whats the best way to do it. should i just copy and paste all the files or is there a better way?
This is exactly what I meant above, in terms of the options SyncToy gives you.how do you exactly make a batch file? this is what i want my external to do. basically updated the newer files instead of of putting the whole folder again
SyncToy will do exactly what you want, and it is free from Microsoft. I use this on my computer and my wife's computer to back files up to a server, which would work roughly the same as an external drive. It also gives options for how to handle duplicate files and such.
It doesn't need to be updated, and it will install just fine on Vista x64....it just needs a dll file replaced for it to run. Let me know if you need more details about it. It works perfectly for what the OP is looking for, and easy enough for my wife to use it.doesnt seem to be updated. and doesnt work on vista x64. wont install
