TechieSooner
- Nov 7, 2007
Been thinking a bit about this recently just wanted some input on this.
On our server, it is an SBS 2003. So it is the DC, file storage, email, everything.
Right now, every day about 4PM, I have TrueImage run. It runs and backs up to an external hard drive, that when I leave for the day (5PM or so) I can take it with me the same day. Looking at changing that schedule to run at night though.
Now my question is how good of a backup strategy and what would you change.
The server is an HP (don't have model or anything- I didn't order it, this was before my time). Has RAID5 with a hot spare HDDs, just about the only failover bit on it.
I built a pretty cheap "backup" server from stuff out of Newegg. Got an Athlon X2 6000+ CPU, 2GB RAM, and a single hard drive that's the same size as the partitions (500GB) in the RAID5 array. Stuck it all in a media center case- due to the size being relatively small and easy to move around.
TrueImage Universal Restore should restore to different hardware just fine (having some issues at the moment- haven't worked them out yet).
Any issues with this?
Ideally if the main server goes down for whatever reason, I hope to have a backup up in the same day (if not in several hours).
Really the only thing I think would be an issue is a hardware failure. Just something long enough to overnight a part to get it fixed- so we are looking at 2 days MAX (unless the weekend I may run into an extended time period).
If a software failure, I can restore the image just fine- no problems restoring to different hardware.
I know having two identical servers in a mirror is the ideal way of doing things, but considering I have seen way too many backup situations with other companies FAIL, even if they have a mirror, just don't want to mess with it. That, and cost is very high.
Thanks!
Thanks!
