Skud said:I use Symantec Ghost to make an image of my drive before I format it.. That way if you wanna go back, just dump the image back and your golden..
If you wanna get specific files back, you just use the ghost explorer to extract files from the image you made..
BTW.. Ghost uses compression when it makes the image, so it won't take as much space as just copying from the root to the external drive.
Riley
