( before a certain person chews my ass)
Also for the record. PDC and BDC are no longer proper terms. They are all simply DC's now.
Depends on your DC's functunality level.
if the functunality level is set at win2k, then you can use a win2k server as your back up DC
However, if I'm to make an assumption here, I'm going to guess the 2k3 server was orginally set up with 2k3 functuanlity, in which case, yes, you could not set up a 2kserver as a backup/secondary DC.
There may be a way to reduce the functunalioty level, but I do not know of any ways off the top of my head.
Chilli is correct. In the OP's situation, it all depends on the Domain Functionality Level. To check that,
-Log on to your 2003 DC and open up "Active Directory Domains and Trusts."
-Right-click on your domain and select "Properties."
It will list the current forrest level and domain level. You can make the determination of how to proceed from there.
I still have had to move FSMO roles from 2003 to 2008. they are easy to seize of course, so it doesn't really matter if they are migrated correctly or not.Also for the record. PDC and BDC are no longer proper terms. They are all simply DC's now.
ok you should be good to go..Domain Funtionality Level: Win 2K Mixed
Forest Funtionality Level: Windows 2000
