DlStreamnet
- Mar 10, 2005
Hi guys
I have a Cisco 861 which connects to a BTnet connection using FA0
I would like to connect FA1 to an existing ADSL router which will have no security on it at all, and simply forward all ports to the Cisco (technically a DMZ?)
Then when the 861 fails I would like to make the ADSL router take over default gateway functionality.
How would I configure this?
I'm thinking a static route with a higher AD?
Or if the modem supports it, put it in modem only mode and let the Cisco handle authentication?
The problem is they have static nat port forwards for internal web servers, how would it know to change to the other connection if the BTnet failed?
