Backlight bleed on LG227WTG
mwalt2
I finally replaced my old CRT with a LG 227WTG today. Since I have never owned a LCD monitor, I was wondering how bad the backlight bleeding is on the monitor I have (ie is it acceptable and can it be expected from another LG227?). I can notice it if I have a darker wallpaper and things like when windows is booting. I have attached a picture of it. The orange light is just the camera's autofocus light. The brightness was set at max for the picture if that changes anything. The taskbar was also on auto-hide, so that's probably what the bright white line across the bottom is...
On another note, when the driver is installed, does it put the color profile somewhere so that when you turn on color management in firefox, firefox finds it...and in Photoshop, do I just choose Monitor RGG - LG 227W?
Thanks for the help.
With that little backlight bleed, you are fortunate.
Most LCDs I have seen have far less brightness uniformity across the whole screen (there are noticeable bright areas) and edge bleed is higher too.
Just got mine yesterday... it has a little on the top and bottom... can't really notice it unless I'm staring at a black screen. Very happy with it so far.
By the way, how high can you raise your refresh rate? I only have 59 and 60hz available... but the monitor was advertised at 75hz if I'm not mistaken.
I believe mine is about the same actually, it might actually even be a little more in some places, gotta check. In any case, that's not a lot of bleed at all, like others have said, it's a very small amount.
Thanks for the replies. It's good (I guess :)) to hear that it's what's expected with these LCD's.
I've found that lowering the monitor's brightness level a bit reduces backlight bleed.
