Backing up the backups in WHS?
iroc409
I am quite happy with Windows Home Server except for one thing—it does not give the option to back up the backups! These files are important and I need to find a good way to do this. What are folks using here to make sure that stuff is safe as well? I do a monthly backup of the shares, but there are a lot of unique files stored in user folders that do not go on the shares (public or private). I also travel a lot so having the files on the server doesn’t do me much good when I am away (and my girlfriend isn’t fond of manual backups). Do I need to consider running WHS in a virtual machine so I can just back up the whole thing?
It doesn't really work that way... I found some script or something that you have to run to terminate the WHS console services, then you can copy the files, then you can restart the services. I guess that will work, just hoping there is something a little smoother.
Connecting an external drive to the system and using it as a backup drive through the console does not allow you to back up the backed up files.
Thanks for the link! That looks like just what I need. Have there been any problems with stability, or bad backups?
No! The WHS BDBB add-in is one of the better add-ins for WHS. It allows you to backup your backup database to local storage, attached external drives or network shares. Restoring the backup database from a BDBB backup is very easy and will completely restore a corrupted backup database.
Excellent! I am going to give it a try as soon as get a chance!
