Corporal79
- Oct 28, 2004
I'm looking for some guidance on a good solution for backing up a single physical server, with a possible gotcha. This server is running a linux VM through virtualbox. Total backup is about 700GB and the internet connection is 8/8 if that changes anything for offsite replication recommendations.
The server is currently using Windows Server Backup successfully (well the backups complete successfully at least) and the owner would like the backups kicked offsite in case something happens to the building or storage onsite. In Q1 2016 (most likely March) there will be a move from this single physical server to a two host virtual environment utilizing Veeam or ShadowProtect replicated offsite most likely to wherever we choose the solution I'm looking for now to be sent off to.
My biggest concern is that the virtualbox VM will cause some kind of hiccup in the backup process, I don't know if VSS will get mess with the running VM or if it will be no issue at all. Anyone run into this?
Thank you
Thank you
