What are the pluses and minus of those screens ?
ok
So how is the response time of them and input leg ?
how is the Samsung XL24 (the only one I know that is wide and 24")
And won't the photos and things look better on them? or the usually LCD today with IPS are better ?
I'd steer clear of LED screens for now just based on cost. They are too much money for what they do. For example: The LED NEC monitor is 21", 4:3 form factor. The MSRP is $3500. Their 30" 16:10 monitor, which has nearly as wide a gamut despite using CCFLs, is only $2200 MSRP.
So unless you have a specific use for that wider gamut, I don't see the money as being worth it, especially since you get a smaller monitor. In terms of uniformity if you go for the NECs it doesn't matter since you can use colourcomp, which makes the panel extremely uniform.
Until the prices get a little more sane, I don't think they are a good buy.
Will LED backlighted displays suffer from backlight bleed in the same fashion as CCFL backlighted displays?
This is what I have found so far
42PFL5603D
42"
LED Dimming backlight,
70W operation
37PFL9732D
37"
LED backlight, Light sensor, subwoofers, good image
208W.
32PFL9603D
32"
LED backlight, Subwoofers
139W
I'm guessing the wattage numbers include the subwoofer's draw at max. It wouldn't be unreasonable for them to spec about 140W (37") and 70W (32") subwoofers.
