Back again for help with another build.
ITOAO
Gaming and general use. I play many game types, shooters, mmo's and have now even messed with a few mobas.
$1500.00 us yes can stretch to $1600.00 if it means a much better part.
Pompano Beach, FL
Case,PSU,ram, hdd, mobo, cpu, video card, OS
Monitor, mouse, kb, possibly the ssd I am using now for my XBO.
6) Will you be overclocking? No I don't think so.
2560x1440 32"
Asap - Unless there is a good reason to wait.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
usb 3.0
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? No, I will want a 64bit OS. I am unsure if if I should get win7 which I have on my machine now, or get 8 while waiting for 10.
I was hoping to get suggestions as I have before. Is the new processor releasing that soon?
Yes, it should be early August.
Typical of new launches, the price of the cheapest motherboards will be a little over $100. You will also have to pay a premium for DDR4 if you buy it next month.
But since you don't have a restrictive budget, there should be more than enough play for that.
I'm not so sure about availability, because the Broadwell 4-core desktop launch came and went:
http://www.techspot.com/review/1028-intel-core-i7-5775c-broadwell/
What are the chances that Intel will be on-the-ball with it's replacement?
Well there is no rush. It is more of a want it than need it. So perhaps I should wait until then.
