Averhoeven
- Apr 24, 2007
Just did my first OC. The FSB is at 1600 right now (wouldn't boot at 1640 and I figured 3.6ghz was a pretty solid OC and all I need/want). I've run Orthos so far (chugging along right now) without probs. Vista core multimeter monitor shows 100% on both cores and between 95% and 99% on the RAM.
Ran Orthos ran for 30 minutes at these settings and after about 20 mins was seeing temps around 70C (70CPU/66Core0/66Core1 was the highest it registered). Is it time to go seeing whether I can drop the voltage (currently at 1.45) or should I lower the clock to drop the temps first? I initially raised the Core to 1.45V, the FSB to 1.5V and the nForce SPP to 1.5V as was recommended in a guide I saw. Which of these should I be dropping/focusing on until I reach a minimum stable point? Which is most important for temps/stability?
In case it matters, once everythis is set and stable it will be a gaming machine. My goal is not to keep pushing it, I just want it at a nice OC (that's why I bought the Tuniq) that is stable and pushes my games as well as this setup reasonably can.
System:
E6600 with a Tuniq Tower 120
eVGA 680i
eVGA 8800GTX (doubt I'll toy with this)
Corsair XMS2 DDR2-800 at 4-4-4-12 T2 (haven't played with this at all yet, probably won't)
Corsair HX620 PSU
***Just adding in the other settings I modified in case anybody feels the urge to double check it since this is my 1st time OCing. Also, any things to check would be good.
CPU Thermal Control: Disabled
C1E Enhanced Holt State: Disabled
Intel Speedstep: Disabled
CPU Speed Spectrum: Disabled
HT Spread Spectrum: Disabled
PCIe Spread Spectrum (SPP and MCP): Disabled
SATA Spread Spectrum: Disabled
System:
eVGA 680i
Corsair HX620 PSU
