dondan
- Apr 15, 2013
>> The last days I had a lof of time, so i designed a new Case <<
The new Case is not the A+, but a case based on the original Steam Machine. The name isn’t final but I called it actual B3.
Technical Spec’s:
Iam not sure if I should support default GPU brackets or custom brackets like in the drawings. The advantage of custom brackets is that I could make the case width 20-25mm smaller.
By using the HDPlex 250W DC-Powerboard, it is possible to mount a 120mm Fan with an 120m AIO Watercoolingsolution under it.
The case consist out of less party and is very easy to bend.
Pictures:
![](http://abload.de/thumb/1oej5h.jpg)
![](http://abload.de/thumb/2pwkax.jpg)
![](http://abload.de/thumb/3rnj0j.jpg)
![](http://abload.de/thumb/408kc8.jpg)
![](http://abload.de/thumb/5f6kqq.jpg)
![](http://abload.de/thumb/7c2ks9.jpg)
![](http://abload.de/thumb/vergleichqxj31.jpg)
![](http://abload.de/thumb/render1_2rbsxd.jpg)
![](http://abload.de/thumb/render2_2rusr8.jpg)
All pictures not as thumpnail (full size):
Technical Spec’s:
- Dimensions: 68.5mm, 316.5mm, 306mm (HxBxT)
- Volume: 6,63 Liter
- Graficcard: max length 295mm, dualslot
- Motherboard: ITX
- Power-Supply: SFX, SFX-L and HD-Plex250W + 120mm Fan
- Harddrive: 2x 2,5“ HDD/SSD
- Cooler: CPU-Cooler max height up to 48mm
Pictures:
![1oej5h.jpg](http://abload.de/img/1oej5h.jpg)
![2pwkax.jpg](http://abload.de/img/2pwkax.jpg)
![3rnj0j.jpg](http://abload.de/img/3rnj0j.jpg)
![408kc8.jpg](http://abload.de/img/408kc8.jpg)
![5f6kqq.jpg](http://abload.de/img/5f6kqq.jpg)
![7c2ks9.jpg](http://abload.de/img/7c2ks9.jpg)
![vergleichqxj31.jpg](http://abload.de/img/vergleichqxj31.jpg)
![render1_2rbsxd.jpg](http://abload.de/img/render1_2rbsxd.jpg)
![render2_2rusr8.jpg](http://abload.de/img/render2_2rusr8.jpg)
