- Mar 21, 2007
Note: if you get red Xs instead of images refresh the page. My webhost is being retarded at the moment....
In the beginning,
In November 2006 I built my 1st gaming rig since the Half-life 1 era, an E6600 powered machine with a brand new at the time 8800gts housed in a beat up old Thermaltake shark. Pure PC Gaming bliss! A bit later when it came time to upgrade the case I picked the 900 due to its modularity, high airflow and mostly because its a cool looking case. It's been with me ever since.
A couple years later,
About two and a half years ago I took plunge and added water cooling to the system and got a bit more serious about cable management. The mess in the picture above with the PCI-E power got cleaned up by stepping up from a 280 to a 285 which did not need a 8pin adapter. At the same time I moved from multiple drives to a single 500gb mounted vertically in the rear fan grill.
Below is a recent picture from November when I lost my power supply, rather than take the time to actually replace it I just set the new unit next to the machine and ran it this way for around a month until I had time to take things apart.
That was then, this is now,
It's that time again, yes sir its upgrade time. I took some cash from a recent contract and purchased the following,
What have we here?
The base chassis with all exterior components removed and new pc hardware installed for the time being while the exterior work gets done.
Santa brought me some NZXT fans, Feaser white tube, black hose clamps, IandH Deadwater and black Anti-Kink for Christmas.
The exterior components ready for cleanup.
The old water-cooling components all cleaned up and ready to install again.
And finally some raw materials, specifically some 16ga mild steel sheet and some perforated steel. This will be used to fabricate the new drive cage.
That's it for now, I'll have some pics up shortly of the new drive mounting and cage, until then good evening and happy modding
In the beginning,
- EVGA GTX580
- Intel Core i7 950
- ASUS Sabertooth X58
- 6gb Mushkin Silverline 1600mhz
- Crucial C300 64gb SSD
- Stuff all of the above plus 2 500gb Caviar drives and water cooling gear into this case
- Clean up the paint and other aesthetics
- Show folks what can be done with basic tools found in a normal garage.
What have we here?
