B type panel mount USB connector?
Mister X
Does anybody know of a source for one of these creatures?
Hopefully one that is not made by Bulgin. ;)
Easiest way to get one is probably to gut a cheap USB device, like a hub or a drive enclosure.
Unless you need it to be an industrial type connector, a nice ghetto solution would be to harvest one from a cheap/old USB hub. Or just about anything with a PCB mounted A-Type USB connector.
-Ed
That one isn't panel mount, it's PC mount. However, part number URB-1001B-SC might be suitable.
I think I got this sorted out... but thanks for the replies.
Even the ones with the hot linked images. ;)
Mister X
So did you order the one from L-Com? What's the depth of that connector?
Thanks.
Yup, the one in the pic is from Lcom.
The depth is roughtly 1 3/8" and it sticks out of the panel about 1/4" which kinda sucks but some spacers will make short work out of correcting that. ;)
I got a pair of the Neutrik ones from the link above today..... those are pretty cool.
Thanks for the info. Where'd you buy the Neutriks? Direct?
I didn't think much of this thread until now. I'm putting together a few VFD setups with USB interfaces, so now I'm taking notes ;)
Yea, directly from Neutrik.
They are freaking monsters though (it's a inch and three eighths deep before plugging anything into it)
Mister X, what's the trick to getting them to sell me a few connectors? The guy who responded gave me the whole "minimum 10,000 pcs" line, and I somehow doubt you bought that many ;)
