AXIM X50v issues.
dwayne001
My axim is just under a year old and it's on the blink.
The earphones don't work. I plug in and find myself twisting the plugged in earphones and pushing and pulling hte plug until i find sound....which then only usually comes out of the left side earphone speaker.
Then there's the issue of the cards. My 5gb ST1 card was working fine until last night when suddenly, I turned it on and the system pretended it had no CF card in there. I removed it and put it into the ATech 9 in one reader i have and the light went from Green, when I put it in, to Red (usually reserved for reading data) There it stays at red and the XP SP 2 machine doesn't acknowledge its presence. Please insert disk into M or something to that effect.
Taking the drive out of the slot leaves the card reader with a red light until i open the case up and unplug it.
Disk Management doesn't read the card either when it's inserted into the slot.
There's also a charging issue where if it's on and pugged in directly. the light will go off and it'll cease to charge, forcing me to turn it off and then turn it back on to resume charging. It's SO annoying.
Any suggestions?
I called up dell. Apparently, if you own the device for less than a year and the innards break they'll send you a fully functional one for free, anda box to send your old one back in. Talk about smooth!
I guess kill the thread?
