ax860 fan mod
FirePrime
Hi is it possible to replace the vanilla fan "San Ace 120" (http://db.sanyodenki.co.jp/product_db_e/coolingfan/dcfan/dc_fan_detail.php?master_id=2016) it a Cooler Master SickleFlow
or it a Enermax T.b. Silence
without damaging the PSU or causing malfunctions with on board fan controller ?
thx in advance
Have to look at the details of each fan. The unknown here is what the fan controller in the PSU max output is. The fans you mentioned will draw more wattage to operate than the San Ace. Also, both fans will require you to remove the RPM sensor (yellow wire in most cases) since both have three pin connectors. Shouldn't be a big deal but I thought I'd mention it.
Here's a quick and dirty spreadsheet with specs taken directly from manufactuer's sites for your info:
what if i connect the fan into the motherboard and ignore the on board fan controller
will the power supply still work ?
