Award bios problem...
legcramp
ok, i flashed my gigabyte k8n pro to a k8n on accident...i thought they were the same thing....
i tried to use awdflash to flash back... no use.. i rebooted.... after flash ofcourse...i get this..
Award Bootblock bios v.10 copyright (c) 2000, award software, inc Scanning Bios Image in Hard drive
my key board is non responsive......
it doesn't seem to be reading from anything....
and i cannot get into anything else.. besides this screen.. tried clearing cmos..but that's all it seems i can do... HELP!!!!
and at the end if i have to rma...how would i do this?
guys come on.. this is an emergency... please fellow members~!!!!! :(
please!!!!! google has no answers and because i can't flash back because my floppy/keyboard is not responsive.... it just stays at
Scanning Bios Image in Hard drive...|
try finding out where it scans the harddrive for a bios, throw it into another sys and put the right bios where it checks, this may fuck windows up though it freaks when it detects a new mobo
Get bios chip replacement from gigabyte.
Or, you can try what they called it hot-flashing, but ur gonna need a second mobo wif the same make/model. Basically ur using the 2nd working mobo to boot to dos, then while the system is still on put the faulty bios chip into that mobo and flash it with the correct bios, then put it back.
The latter one is way riskier and need similar mobo. Try googling "hot flashing".
or click here
hope that helps
or click here
hope that helps
I would try that if i had great soldering skills....the darn chips are soldered onto the motherboard.....exactly like here...
http://img.ferra.ru/pubimages/27159.jpg
gigabyte has not reponded back in 3 days..and my dual bios won't and will not kick in..no jumper...and the k8n board does not support dual bios..which i flashed to...(idiot)
So....i can contact someone to unsolder and switch the chips around for me..or....i can carelessly with all my might rip those chips off and duck tape them ..... :eek:
gigabyte better hurry and respond! I am getting desperate!
