Hi,
I just bought (used) an AMD Athlon 64 3000+ (754) and an Epox 8KDA3J along with 1x512MB RAM, 250GB SATA HD and am using an older (cheap?) PSU. I got the system up and running as soon as it was assembled. I got XP Pro installed (put Vista on a seperate partition as well) and had the computer running fine for over a day. I messed up the install so I reinstalled and had the computer running fine. I got a BSOD and it rebooted. It was running when I left it and when I came back it was frozen on a garbled POST screen. I shut it down and restarted. Nothing happened, no POST. No Bios screen. I checked the LED display, I'm getting a code 18 which is:
Does this mean I need to go find another CPU (which one?) to get the PC to boot, flash the bios then put my 3000+ back in?
I've cleared the CMOS, reseated the CPU, disconnected EVERYTHING and still get code 18. I have only found one thread which says:"Detect CPU information including brand, SMI type (Cyrix or Intel) and CPU level (586 or 686)"
Obviously this is for an Intel system but it still applies (same type of bios).Means the board doesn't know how to boot your cpu, IE it doesn't have the microcode. You need an earlier non 64bit cpu ie: 520 and flash the bios.
