AW3420 Alienware command center?
LigTasm
I have an AW3420, been trying to figure out how to make the lighting do what I want for a while now. I have finally after almost 6 months managed to sucessfully install the command center, but everything EXCEPT the FX section works. If I try to do anything with the lighting it wants me to get some update from the microsoft store, which I can't get to because I don't use a microsoft login. Does anyone know how to make this POS software work?
Ok well I figured out how to at least shut them off, you can't use the USB hub on the monitor. You must not connect the USB to the computer and then shut off the lights in the display menu. If you connect it they will do whatever they want even if you don't install and Alienware software.
