avoiding shortage :(
mjz_5
Hi guys,
I just bought a new case and when I place my motherboard into it, it shorts out when I press the power switch. I tried electrical tape on the motherboard plate punch-ups to try to avoid it, but to no avail..
Please help!!!!!!
Thanks
Are you 100% certain that it's the case you bought? Have you tried to boot the motherboard outside the case to make sure?
yeah, it works fine when outside the case
You installed the standoffs and screwed them down? Have you installed all the standoffs or just the ones that line up with the holes on the motherboard itself?
You might have one to many standoffs shorting things out.
the thing is that this case doesn't have any standouts/studs. all it has is 9 punch-outs/bends in the MB plate on the case. the motherboard screws directly into it. I used all 9 punch-outs, since my abit-it7 has 9 holes.
thanks in advance
