My problem with that is that some of the basic info there is wrong, eg:thejunker said:ATI has stepped up lately with their new drivers.
Some good comparison shots here:
http://www.firingsquad.com/hardware/ati_catalyst_5.13_video_quality/
Purevideo does noise reduction as part of the scaling algorithim but it's kind of basic stuff like how you would find in any MPEG2 codec but the point is it's there. Then again what do I care, I use FFDShow on my DVDs for postprocessing.Neither NVIDIA nor XGI offer noise reduction algorithms.
NV supports component out on the 6150-6600 series, PCIE 6800 and 7x00 series. NV's support for DVI to HDMI has always been much better though.steviep said:Actually, I think AVIVO is a bit better than NV's solution, at least in terms of input options on their AIW cards... I think they even include the component output dongles with those.
CrimandEvil said:Purevideo does noise reduction as part of the scaling algorithim but it's kind of basic stuff like how you would find in any MPEG2 codec but the point is it's there. Then again what do I care, I use FFDShow on my DVDs for postprocessing.![]()
CrimandEvil said:NV supports component out on the 6150-6600 series, PCIE 6800 and 7x00 series. NV's support for DVI to HDMI has always been much better though.
