Here give this a try I like it HJSplit2.2 I use on files of 1gig it does very well but when it is done you will have to rename all the split files (example say it is a .vob file when it is split the splits are called *.vob.001 , .vob.002 and so on then you just remove the .001 , .002 at the end of the files but I find that adding the .001 in brakets (001) in the newly split file helps in keeping track of them) but you can split the file into kilobytes or megabytes depending on the amount files you want to have to rename.
