So, trying to get some viruses off a friends PC and ran AdAware, Spybot S&D then AVG. the first two found and removed like 250 combined files. AVG found 15 infected files and fixed them. Now the system just endlessly loops and will not boot, I see about ten seconds of the windows splash. If I go into f8 and set it to disable automatic reboot on fail then I get a blue screen that says the system could not find the file basevnp32, which I'm guessing is something AVG removed, and shouldn't have. No safe mode doesn't work either, or the 'last known good configuration'. Any way to fix this short of taking out the HD and putting the files back manually.
