Yeah, but there's no reason for me not to put in a huge one really, price difference is non exsistant and the box will be standing in a room and not move anyway.ashmedai said:XP-120 is fricking huge, doesn't do any better than the XP-90 either and when/if it ever does it's only marginal. Even at 2.8GHz an A64 isn't going to make more than 30C, tops out at about 40C under extended heavy load.
Great I was hoping for thatashmedai said:Stock fans...you just don't install it. Retail pack comes with a heatsink & CPU in a nice pretty box, they're not glued together or anything weird like that.
ashmedai said:If you consider $50 vs $25-30 insignificant, and don't care that it has trouble fitting on most motherboards, knock yourself out. It certainly looks impressive if nothing else.
Don't forget to use the sticky to post your results. ^_^
