Heliocentrical
- Mar 28, 2005
I would like to know what temps you Celeron D 340 users are getting on air. The average temps I've found while googling this topic are about 35c to 39c. The lowest I've ever gotten while using speedfan 4.5 to max out the rpm on the HSF is 48c. The idle temp with the fan set at the system default speed is about 55c. I dont see how you can get 35c on air? I know that the HSF is a stock intel but it's massive. Anyway, lets hear those temps. I need to know if this normal or if something needs to be done to get it lower. Thanks.
Processor Specs:
Prescott Model:Celeron D 340 Frequency: 2.933Ghz
FSB: 533Mhz
Cache L2: 256k
Voltage: 1.287V-1.400V
Max Die Temp.: 67º C
Also, you folding folks might want to weigh in on this, it's probably F@H's fault my cpu temps are so high.
Processor Specs:
FSB: 533Mhz
Cache L2: 256k
