average pump capacity, post urs
wayne
i m starting to get into water cooling and would like to know the speed of decent pumps... because in the hot deals forum, someone had posted a 200gph pump for $8 so i may wanna get into overclocking just for minor ones...
as for now, i just want to know the speed of ur pumps, like how GPHs, and ur model, and also, if possible, a picture so i would know the size, and look of it
all this is for determining the range around the power of pumps most people are using/needing
thanks
Danner mag drive model #5
500gph
10.5' head
$57.99 at petsmart.com
Can be run in-line or submerged.
Eheim 1250 - rated at 317GPH
thats twice as much water being pumped out then my shower head;)
Mag 3, 350gph and 10.5ft max head. Charts show it has better flow characteristics than any other pump other than the big time Iwakis or the Johnsons (possibly the mag 5 or better, as well as probably the eheim 1260).
me got the Eheim 1250 also
wouldn't it be better to pump water though the rad first then water block since the pump adds heat to the water? www.all4amd.netfirms.com thats my setup
I agree, that's how I've always done my watercooling setups. I doubt it makes that much of a difference, but every little bit counts.(sitting at 36'C under full-load, 2500+ oc'd to 2200mhz, sucks though, it's unstable at anything higher at any voltages up to 1.85, didn't bother trying higher than that).
Rainbow Lifeguard Quiet One
0ft=1140gph
1ft=943gph
2ft=830gph
3ft=752gph
4ft=724gph
5ft=656gph
6ft=640gph
7ft=613gph
max--15’
It will move 724gph thru 1" tube at 4 feet
maybe I need to go to a 1" loop... :)
Danner Mag (model) 5
10.5ft Head
500gph
Inline or Submersible
$49.99 online store
Good luck finding a 1'' barbed waterblock :)
twin danner mag 5's...specs as stated in previous posts....
1" loop would be frickin insane...
if you do it...i want pics...lol :D
