Average overclock for 3.2e pentium prescott?
kalpha
I currently have the regular crucial ram pc-3200 2x512 cas 3 ram and am able to overclock my 3.2ghz @ 3.73 with 233 fsb 1:1 at 3-3-3-7 stable. My prime95 torture test 2(for maximum heat) will cause my cpu temp to max out at 46 degrees C. If got better ram, do you guys think would I have a good chance of overclocking to 4.2 ghz, or is that asking too much?
if your temps stay low and your PSU holds up..maybe..but each chip overclocks differently..so you'll just have to try it
that's not bad, if that's the type of RAM i think it is (value select???)
