Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I built one for a teacher and we had some major temp problems, the thing was running like 55 idle and 69 load. Seems that those darn 2400+ just like to run a little hot.
I got like 51 load and 46 idle, ever since i took my heatsink and and put in back on its been higher, i use to never break 50 and never break 43 idle. What do u think i should do? DO u think i should buy this heatsink?
When you took it off and put it back on, you needed to re-artic silver the processor. Since I don't think you did the contact between the HSF and Proc has been mest up.
As for buying a different HSF yeah sure, just not that one, looking into a Thermalright like the SLK-900 or something similar.
It all depends on your heatsink and room temp. Mine runs with a small overclock at 37c to 38c idel to 45c to 46c load. The difference in temps I would say depends on what we have it in the house at the time. You can see what heatsink and all I have in my sig. I have had it as high as 2.25 or so and my temps went as high as 50c I think it was. But to get that I had to up the V and that really helps the temps go up fast.
If I was running as hot as you are I would get a better heatsink asp. I am told that the XP can take them temps no problem. But I like mine down close to what I have if not better.
I run mine OC'd to speed in sig, I use a Vantec Aeroflow, and the cpu almost never goes above 35C under load, sits at around 30C idle. Hottest it ever was recently was 43C at a lan party with 6 computers, room was around 79F
