AVADirect Build: Sanity Check
BiggerBoat
My current system is several years old (a record for me -- I used to build my own every 18 months). I am finally feeling the pain and it's time for a new system. I'm considering going to a boutique this time; I just don't have the time or energy to deal with it myself.
I've done some research (enough to be dangerous), and have put together an initial build at AVADirect. I'd really appreciate any initial thoughts on improving the build, after which I will give AVA a call to deal with any further questions. I fully realize that I am probably making some idiotic mistakes here. Don't make too much fun of me. Thanks!
Here's the build:
  • INTEL, Core™ 2 Duo E6850 Dual-Core, 3.0Ghz, 1333MHz FSB, 4MB L2 Cache, 65nm EM64T EIST VT XD, Retail
  • ZALMAN, CNPS7000B-CuLED Copper CPU Cooler, Socket 478/754/939/940, Blue LED
  • SERVICE, Overclocking, Dual-Core CPU, 20-30% Performance Increase
  • ASUS, P5N32-E SLI, LGA775, nForce 680i SLI, 1333MHz FSB, DDR2-800 8GB /4, PCIe x16 SLI /3, SATA 3Gb/s RAID 5 /6, HDA, GbLAN /2, FW /2, ATX, Retail
  • CORSAIR, 2GB (2 x 1GB) XMS2 PC2-8500 DDR2 1066MHz CL5 (5-5-5-15-2T) 2.2V SDRAM DIMM, Non-ECC
  • eVGA, e-GeForce 8600GTS Superclocked 720MHz, 256MB DDR3 2100MHz, PCIe x16 SLI, 2x DVI, HDTV-Out, Retail
  • WESTERN DIGITAL, 400GB WD Caviar® SE16 (WD4000AAKS), SATA 300MB/s, 7200 RPM, 16MB Cache
  • RAID, No RAID, Independent HDD Drives
  • MITSUMI, Black Internal 1.44MB 3.5" Floppy Drive
  • LITE-ON, LH-16D1P-187 Black 16x48x DVD-ROM Drive, IDE, Retail
  • LITE-ON, LH-20A1H Black/White 20x DVD±RW Dual-Layer Burner w/ LightScribe, EIDE/ATAPI, Retail
  • COOLERMASTER, CM Stacker 830 Evolution (RC-830) Black Tower Case, EATX, No PSU, Aluminum, SLI Certified
  • THERMALTAKE, Toughpower 750W Power Supply w/ Modularized Cable Management, 24-pin ATX12V EPS12V, Quad +12V, SLI Ready / CrossFire Certified
  • AVA, Original Side Panel (may not have window)
  • CUSTOM WIRING, Standard Wiring with Round Cables
  • MICROSOFT, Windows Vista Home Premium Edition 32-bit, OEM
  • GAMING PC, Silver Warranty Package (3 Year Limited Parts, 3 Year Labor Warranty)
  • SERVICE, Standard Shipping (UPS, DHL, or Fedex)
This system will be shared between gaming and work. For work, it's MS Office plus a fair bit of (not demanding) Photoshop. For gaming, the most demanding stuff is Microsoft Flight Simulator, Oblivion, the Total War series, and various others. I run at 1680x1050 and like to have at least 4x AA and 8x Anisotropic. I do want to be somewhat future proofed for games coming out in the next year or 18 months. I'd like to keep the cost around 2k. I might do things like SLI or upgrade to quad-core later on if the performance difference warrants it.
I am upgrading from an AMD64 3000+ and a 6800GT.
Again, thanks.
I put together a rough draft for the system I'll be ordering within the next day or two Here.
It's a quad-core with 8800GTX and 4 gigs of ram, 500gb HDD and SATA DVD RW and Vista Ultimate for well under $2k.
If you're spending $2k for the build you just outlined, and you are here, I think you should know better and build the far superior system yourself for less.
If your planning on going SLI down the road I would upgrade to a 8800GTX honestly or it would not be worth it. Then again what size monitor are you using? Also if you want to shave off a few bucks. Go with the Thermaltake Armor case, but that depends on what you like your case to look like. I love mine honesly although it weighs a ton :p
Everything else looks pretty good from what I can tell. Juse give them a call and talk to Misha and tell him what you are looking for and how long you want it to last. He will help you out a ton.
Heatsink won't be adequate for a overclocked E6850.
Graphics card is severely underpowered.
can that heatsink even fit on the e6850? it doesn't list socket 775...
if you want to game (i see you listed oblivion), you'd want at least an 880gts 320mb if not the 640mb version
and i'd get 4 gigs of ram, you don't need the super high end stuff with a 20% o/c, you can do just fine with ddr2 800 (that'll get your e6850 to 3.6ghz exactly 20%)
Sure, you'll just need an adapter for it. Don't bother with it. Its not much better than Intel Stock. Go with a tower cooler, like the Scythe Ninja Plus Rev.B, Tuniq Tower 120, or Thermalright Ultra 120 Extreme + Scythe S-Flex fan.
What size monitor will you be using? SLI is only needed for resolutions of 1920x1080 or larger. If you don't have a 24" LCD or bigger, then I'd suggest switching to a P35 motherboard. Even with a 24" LCD, a single GTX would still be an option. If you still want to keep the SLI board, at least go with the eVGA 680i SLI A1 board instead -- much better than that Asus you listed.
The GTS 640MB is nice for 20" LCDs, but, of course, the GTX is better.
Thanks everyone for the advice. To answer what's been asked a couple of times, my monitor is a Dell 2005FPW 21" (1680x1050 native). Even if I change out monitors, I probably won't go bigger.
So it sounds like SLI will never be a concern at that max resolution?
Yeah SLI would not be a way to go with just a 21" Monitor so a single gtx would be good. If you did that you can go with the P35 motherboard and drop your PSU down to a Corsair 620 watt maybe even the 520, but I am not sure if that would be enough for the GTX.
Yeah change your heatsink as well. If you don't want to spend a ton of money on one then go with the Zalman 9700 which is the same one I use and it does fine as far as overclocking goes for my rig.
Yah, no need for SLI with 1680x1050. The 520W Corsair will be fine for a single GTX and a bunch of drives, along with OC'ing a C2D.
I agree, switch to a P35 board, like the Asus P5K or Gigabyte GA-P35-DS3R (i'm not sure what avadirect offers). Don't bother with the P5K deluxe unless you absolutely need all of its extra features -- its just an overpriced board.
The Zalman is ok, but the three I listed in my earlier post would be better. The Zalman costs more than the Ninja, yet it performs the same.
I only offer my advice because you title the thead "sanity check."
Check out the final invoices I posted in my build thread after ordering everything. It's DIY, and I don't know your reasons for not wanting to DIY, but if it is shear laziness, consider what I got for ~$2000 AR, and compare that to what you will get from AVAdirect.
My machine
