Yes?
Drunken posting? FTW?
Although usually those are verbose, not the other way around...
LOL
Yeah diarrhea of the mouth usually accompanies half a case of the good stuff.
Half a case... keepin' it [H]
After thinking about it long and hard when it comes back I am not going to use it. I'll keep it in the box forever or sell it.
No. I want rid of it for good. Just the thought of having too deal with same shit problems again makes me sick.
so you get 3 fps in one game, WoW, with no proof of SS, refuse to give data about other games, and claim the whole PC is a POS. You're the most rational person I've met in my life.
It died 100% how was I going to post anything? What does SS mean? My hard drives will burn up if put them in this pc too long just pull off a screenshot. I couldn't even play a video without it being choppy as hell that is not normal. I'm getting rid of the thing on ebay when it comes back. I don't care if all I get is $100 out of it. Using this old pc here is bliss compared to the living hell its put me though. That is just what I want to avoid troubleshoot the pos till hell freezes over just so it works as good as a two year old pc.
huh? Is this a joke?![]()
I'm not miserable atm using this old pc I would to stay that way. Like I said before I am not looking forward to getting it back and having to start this nightmare again. Total loss so far $110. Blame me for everything I should of wasted more money shipping it than trying to get it to work at least in some condition. I would of posted some pics but I was busy if you hadn't noticed trying to get the thing to actually work. I have pics they are on my data hard drive. If I try get them off it means I have put it in this pc and the last time I did that to test if they still worked after the pc died they got hot as hell from no fans in this old pcs case. Sorry but I'm not risking all my data just to get a pic now.
Both companies are excellent.
I just happened to go with Maingear and I couldn't be more thrilled with them from start to finish.![]()
$80 +$80= $160 shipping that is why. I do have an idea of what I'm doing but not intricate repairs. I never attempted anything I was not capable of. You didn't see me take out the cpu and see if it was seated right did you? Most of what I did was changing wires which is not hard but the case buttons being wired was a bit more difficult but doable thanks to the q connector. As for adding my data hard drives I've done that before nothing difficult. If you can't figure how do something that simple then you don't ever need to own a pc.Why were you trying to fix it yourself? Without much of an idea on how to fix it?
Ava has since told me they have fixed the case buttons and are trying to get the pc stable at stock ram speeds. It seems something else is wrong with it if it can't be stable at stock 800mhz ram speeds. They are probably testing the ram at 2.1v and since this asus board is a pos even worse than evga I think its most likely fried the new ram since the thing can't do any correct voltages and overvolts everything.
Read the lower ones. Ava confirmed the ram was bad and I saw it in the bios how it could never do correct voltages. It either overvolted the ram or under if you tried to compensate for it by lowering it. From what I have looked about it on google its well known and one of the reasons it was discontinued so soon after its release. The evga board at least if you set ram to 2.1v you got 2.1v not 2.2 2.3 or some oddball voltage.Hmm...???
how long did the build take?
Guess what? I knew one of you would chew up my ass over it and guess what?So in other words you got the system back and immediately started fiddling around inside of it again.Wouldn't it have made more sense to include everything when you sent it back and have them install it? Way too many gray areas here.
