I, as of about two months now, have been getting the siren issue with my AV8. It happens, for the most part, randomly. Sometimes i get the siren on boot, but it boots up just fine as the siren is wailing. No errors, and no wierd post codes. It is as tho the siren is just for "effect". Also, it sometimes happens when my computer is simply idling. I'll be sitting watching TV, and then out of no where I get the two tone beep for maybe 4 seconds and then it goes away. I am very confused. It doesn't stop POST, nor does it restart the comp when it happens. Here are some specs...
PSU: Thermaltake purepower 420
GC: Ati AIW-pro 9800
2 HDD, 2DVD drives.
I cannot pinpoint when the error started happening. The computer worked just fine for more than a year or so. A quick check of voltages and temps from SpeedFan yeilds....
Voltages:
HTV: 1.25V
CORE: 1.52V
DDRVDD: 2.64V
3.3V: 3.42V
5V: 5.22V (should I be worried about this)
NBVDD: 1.56V
AGP: 1.59V
DDRVTT: 1.34V
5VSB: 5.27V
3VDUAL: 3.37V
SBVDD: 2.56V
Temps:
HD0: 44C
HD1: 44C
CPU: 57C
SYS: 37C
PWM: 45C
Fan Speeds:
CPU: 2640 RPM
NB: 2340 RPM
Any Ideas what I should replace, and If i need to replace the PSU, which one should I get (must be bought from Best Buy/CompUSA/Other Retail Place)
2 HDD, 2DVD drives.
Voltages:
HTV: 1.25V
CORE: 1.52V
DDRVDD: 2.64V
3.3V: 3.42V
NBVDD: 1.56V
AGP: 1.59V
DDRVTT: 1.34V
5VSB: 5.27V
3VDUAL: 3.37V
SBVDD: 2.56V
Temps:
HD0: 44C
HD1: 44C
CPU: 57C
SYS: 37C
PWM: 45C
Fan Speeds:
CPU: 2640 RPM
NB: 2340 RPM
