AV8 installation problem
DaMaDo
I had one and had to RMA it b/c the video never showed up (monitors always blank).
Got the new one and it won't detect my SATA drives....
If I hit tab while booting it lists my array, but it won't boot off them.
I figured ok maybe diff mobo's need new arrays formed or something...so I was going to redo the windows installation, but when I connected the floppy to load the SATA drivers, the floppy drive light is always on....from way back when I remember the ight would come on when I had something like an IDE connected incorrectly...but my CD drive works fine and I can't connect the SATA drives backwards so I dunno what it can be....another thing that bothers me is my RAM getting really hot...
Anyone knows what's going on? Any possibilities? Specs in Sig
ok how about just the floppy drive? Anyone know what would cause the floppy drive light to remain on and not work? (besides the drive being broken)
Most likely its either the power connector to the floppy upside down or the floppy connector is upside down - if i recall correctly a lot of FDDs dont have guide slots so you cant goof up ;)
Thanks, but the floppy cable and the floppy and mobo both have guides...the connectors are even labled drive and motherboard.
The power connector also can only be connected one way =/
when using SATA on the board did you have to load the drivers? I'm running into the same problem although I'm stuck when its verifying the DMI pool Data....
If thats right but the light is on maybe your FDD is DOA then :(
Edit: Never mind... I figured it out. You need to load the SATA Raid Driver off of the floppy even if you do not want to use RAID, or XP doesn't see the drives. Load the VIA Raid Srivers for XP if thats what you are installing and it works like a champ.
