Av8 + Fx55 = 9f?
mwin
I just got done building a custom watercooled FX55/AV8 machine. Plugged it all up, powered it on, no problems. Got the SATA RAID set up and got Windows to recognize it. Installed Windows. Shut it down. Decided that I'd go ahead and plug in the mouse and network cable. Powered it back up: It powered up and then immediately powered down, posted a 9F. It does that every time you hit the power button.
After looking through the manual to see what a 9F code was (not in there), I searched the internet. I've seen short on the back of the mobo (I'm sure that's not it), inadequate power supply (Ultra XConnect 500W...surely that's good enough), overheating, and outdated bios. I'm going to leave it sitting for a while and then try powering it up again. Anybody else solve this problem?
Cleared the CMOS. That fixed the no-boot issue. Updated the BIOS. Seems to be working now.
Good news. Now overclock that sucka!!! :D
jeebus said:
and how do u clear it, im having some trouble with a 90nm cpu
With the CMOS jumper... But if you are trying to run more than 1 stick of RAM you may want to try just 1 then flash your BIOS to the latest. Then install a second stick if you have it.
