Apathy
- Oct 29, 2004
Running vista64 home premium. auzentech prelude x-fi 7.1 sound card.
My pc (rig in sig) has recurring problems with its audio. Pretty much without fail, at least once a day, my sound will cut out immediately following some beeps and ubrupt noises coming from my speakers.
Symptoms:
- No audio from any application.
- If i try to play a song in winamp, the song will not even start, the time on the song wont budge from 0:00, the slider reflecting progress of the song will not move.
- Rarely it will cause my pc to lockup.
- Sometimes after the loud noises / static start, they will go away within 30 seconds, and my sound will come back.
Solutions tried:
- Restarting pc restores sound, but sometimes the static and 'processing' noises will start before i even get passed the windows login screen.
- I have tried reinstalling audio drivers, no change.
- Attempted switching from "wave" to "direct sound" with teamspeak to see if that was causing the problem since i routinely have teamspeak up and running.
Has anyone had any similar problems to this? It is really annoying me, makes me jump everytime it happens.
**UPDATE*
I have cross posted this from gen hardware in hopes of receiving some help from the audiophiles.
I came across this thread which lead me to trying different bit rates.
http://forum.overclock3d.net/showthread.php?t=20544
I have managed to drastically minimize the problems here. After fiddling with bitrates in the control panel -> sound, i have learned that none of the 16bit modes work. So far 24bit 48kHZ (studio) seems to be holding just fine. However winamp still shows as playing in 16bit 44100kHz.
There are still a few clicks and beeps, but about 95% less so far now than there was before.
Any help and/or input is greatly appreciated.
Symptoms:
Solutions tried:
**UPDATE*
