i own both the auzentech has slightly more stable drivers. it looks just like creative's
the auzentech sounds better than the creative espescially through headphones as it has a headphone amp. i recommend the forte if you game with headphones as i do. I own a pair of A700's and the forte sounds great.
The main difference is the headphone amp on the Forte. The Forte also has higher quality circuitry and includes the software license needed to do multichannel audio via the digital output, but the main selling point is the headphone amp. Its a souped up X-Fi.
I'm happy with my Forte.
Not to thread jack. How would you compare the XFi Elite vs the Forte? I ONLY have headphones hooked up to the card, never have or forsee having speakers.. No amp in the way.
Elite Pro has better input stages, better A/D quality, more I/O (phono pre, MIDI, etc), and so on
Elite Pro should be a little better on the analog output side as well (its up there with the Prelude for analog I/O, the Forte is a bit lower spec'd, I can say with some decent certainty that 99.999% of users couldn't pick one of them out against the other two in a blind test)
both have identical processing power
headphone amp wise, its tough to say, the headphone amp they built into the live drive for Live!, Audigy Plat, and X-Fi Plat was pretty decent
although I've read some speculation that the EP's accessory box (which provides the headphone amp and so on) is closer to the E-MU Microdock than the Live Drive in terms of its opamps and design
I'd probably say unless you've got some really high impedance headphones, the Elite Pro will be comparable to the Forte, at twice the price, so I wouldn't suggest it unless:
A) you already own it
B) you actually need some/all of its I/O abilities (as in, you realize that its a MULTIMEDIA card, not a GAMING card, and you're going to use some of those features (like a small project studio/computer musician setup, an HTPC, etc))
Thanks! I own the EP at the moment and just contemplating what I will replace it with. Reason is the PCI vs PCIx slot in a new built in 2010. Just thinking ahead.
Making a list of sort of things to look into when the time comes. And wanted to guage what sort of upgrade / side grade and hopefully not a downgrade I was looking at.
