Autoupdate isnt working. . .
Tarfu
Can someone please explain the problem with this? I have highlighted the relevant areas of the screenshot.
Creative autoupdate only works with IE 5.5 and above AFAIK
oldmx
Which is why I drew the big arrow pointing at the words "Mozilla Firefox". Is it not higher then IE by several magnitudes?
err. NO FF != IE
one is not greater then the other (in some geeky kind of humour), one is different from the other
if you want to do this in FF, you could install the IE-tabs extension, not as good as FF-native (it relies on ActiveX to do this) but at least within FF
Did you see the sentence below your circle?
"If you are using any other operating system or browser please select Manual Download or click here to proceed."
Firefox is not the same as IE, hence it would be classified as "other browser". I don't know that Firefox is any "magnitudes greater" than IE. I'm currently using Firefox because I'm used to it and like the layout, but don't know that it is any better than IE or Opera. I've found they all have their pros and cons.
